Zum Hauptinhalt wechseln
Die sechste Generation des von Google designten Android Smartphone, welches LG produziert. Modell LG-H790. Veröffentlicht im Oktober 2015.
20 Fragen Alle anzeigen
Microphone not working in call
My Microphone won't work during a call unless I activate loudspeaker mode.
I dropped it in wet grass recently which may be the cause
Mic works on a voice recorder app or while taking videos.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Back up your data and factory reset your phone, if that doesn't fix the issue I'd say you're looking at a faulty Mic. You'll find the part on most site like ebay and even if you ordered it directly from LG. You'll also find disassembly guides for your phone here on ifixit.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I have same problem. Are your phone fixed? If fixed can you guide me how to settle that problem
von
I fixed my issue by cleaning out the microphone hole with a needle. The hole was filled with grunt, once removed the microphone worked.
Be careful not to stick the needle to far in.
Bewertung 0
Antwort hinzufügen
Ben Lyons wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 3,176
