Zum Hauptinhalt wechseln
Erschienen im Juni 2014, zu identifizieren anhand der Modellnummer B051.
I have a serious Problem
Hello I would like to know if there is a way to fix this but my beats solo² s460 stop working when it was playing audio and the device I was using to play it disconnected and the beats froze as soon as it disconnected it was stuck on a blue light and I held down the power button for approximately 10 secs but It was frozen
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I've fixed it the buttons were shifted when I turned them on so the power knob wasn't touching the button to turn it off
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Hi Adain, I would give them a hardreset, If this doesn't work it's an indication that the issue may be hardware related and will need a technician to check soldering, plugs etc.
Press and hold the power button for 10 seconds.
Release the button.
The battery Fuel Gauge LEDs will all blink white, then the first will blink red—this sequence will happen three times.
When the lights stop flashing, the reset is complete.
Bewertung 1
2 Kommentare:
Didn't work thanks though
von
You could attempt to remove the battery and reset it that way.
von
Antwort hinzufügen
Adain Asir wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 651
