Battery problem, stuck on charging loop.
I have a problem with my iShit 5s ( iPhone). It started a while ago, I suppose that after the upgrade to iOS 10. My iPhone won't charge even if it is showing that it's charging. When battery stuck at for ex. 42% it doesn't increase no matter what. I tried different USB cables. I tried to clean the charging port. It's just driving me nut, the point is that sometimes it will charge and sometimes not. The only solution that I found till now is to heat it up with hairdryer, and then it works perfectly. But as I said before, there is no rule when my iPhone will charge or won't... That is just insane because I can't keep with me all the time hairdryer.
I tried the hard reset, soft reset, restoring iPhone.
Does someone of you have any idea what to do? Because now only what I want to do is to kill my iShit....
Ist dies eine gute Frage?
