Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
iTunes error code -1
An old phone form my friends needed restoring as it had a passcode. Everything was working perfectly fine before except it didn't charge, turns out there was a lot of crap in the charging port so when I cleaned it out it charged and worked perfectly
When I went to restore it gets halfway through and returns error -1
i can't seem to find any info about this erorr online
does anybody have any ideas? only thing I can think of is charging port
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Charging port sure sounds like a good possibility.
I gave up on using iTunes error codes to diagnose problems. I would believe it if you told me that they are completely random and mean nothing. Start simple: connect a new Lightning port to the board, connect to iTunes and see if it works. Don't worry about taking the old one out or doing anything fancy. Just plug it in. If it works, you are golden. If not, you only lost about 30 seconds.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I tried it still the same unfortunately. It just crashes and stays with the bar there and the apple logo and returns -1, it will only go away if I unplug or restart
guessing it's toast, very annoying as it worked fine beforehand
thanks anyway
von
I suggest attempting a DFU restore if you haven't already.
Has the battery been replaced before?
von
Well, what do you know...
Took it out of the housing and just had battery and charging port (no screen) didn't work, tried with screen, didn't work...
I thought I'd give it a bath with IPA99. Didn't ultrasonic clean or even remove IMEI shields as I can't at the moment but what do you know it worked and the device is fully restored
No visible signs of water damage
Bewertung 0
4 Kommentare:
ship it!
Then keep researching for when it comes back with the same problem :D
von
and it's back with the same problem lol
doesnt get calls, just says searching or no service so I restored it again and updated and what do you know itunes error -1... so i did the same thing and cleaned it in a bath of IPA and let it dry and it restored again and signal was great until this morning now it has stopped. any ideas what the actual problem is?
von
I'm fairly sure this is a baseband chip fault issue as it's intermittently working. I'm not sure whether it needs to be reballed / reflowed or replaced.
You probably see that the IMEI and modem firmware may disappear together in Settings > General > About phone when it gets the searching and no service.
von
In my opinion it is hardware issue which can be resolved by reflowing the chip (easy version) or more complicated reballing or replacong the chip.
von
It's a hardware problem as said before. Some have worked to heat around simcard tray with an hairblower for 4-5min
Bewertung 0
Error -1 could be caused by connection between device and pc, network and hardware problem.
Bewertung 0
1 Kommentar:
Error -1 is a baseband IC connectivity issue. Reballing the Baseband IC is the best way to fix it.
von
Antwort hinzufügen
David F wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 523
