Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Microphone sounds muffled after port replacement
Replaced the lightening port (phone stopped charging). The microphone sounds muffled to callers. In case it was faulty, I replaced it with 3 different parts with all the same results.
Checked and removed excess adhesive on the microphone, checked placement and made sure the hole is clear, phone charges great with each new part except the microphone is still muffled.
What is going on???
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Are you using the rubber mic housing? Did you make sure it doesn't have any dust in its holes/cavities?
War diese Antwort hilfreich?
Bewertung 1
Probably microphone isn't in correct position, it have to be putted correctly in to hole, if it will be not, youre callers may have problems while calling You like their own voices in their earspeakers.
There's low chance to have damaged 3 mics (everything is possible, you don't know who and how disconected those flex from phone - maybe some1 used to high temperature and melt the speaker), but You can also try use a IPA and toothbrush and gently clear the port on motherboard.
Bewertung 1
I am having this problem now, jliscum31, did you find an answer or solution?
I have replaced the charge port twice. I made sure to not cover the microphone hole with adhesive. I tried to ensure the microphone was lined up in placement. The callers complain he sounds muffled and his voice cuts in and out.
Any thoughts!?
Thank you!
Bewertung 0
Antwort hinzufügen
jliscum31 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 1,442
