Zum Hauptinhalt wechseln
Why do my Christmas lights stop working after a few minutes?
Hello,
I bought a set of outdoor battery operated Christmas LED lights last year and put them on a tree outside. They worked fine for a few days but I soon noticed that they would no longer be lighting 5 or 10 minutes after turning them on. I took them out of storage a few days ago again and the situation was still the same. After working ok for about 5 minutes they are off. Any ideas around what may be causing this would be greatly appreciated?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hi Wallman,
Yes I replaced the batteries with new ones but the result was unfortunately the same.
von
Einen Kommentar hinzufügen
2 Antworten
Have you tried changing the battery? Maybe the current one is low on power. Hope this helps.
War diese Antwort hilfreich?
Bewertung 0
It can also be th outlet is needing replaced. It may be overheating.
Bewertung 0
1 Kommentar:
LED bulbs require more power than incandescent bulbs, so if you daisy chained more than 5 or so, they get overloaded and go out.
von
Antwort hinzufügen
Padraig wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 2,387
