Zum Hauptinhalt wechseln
Black & Decker FT1000 Flex-Tube Blower (Type 1) is an electric hand-held blower. It includes 140 mph air-speed, joystick control, and a low noise level. It can be used with the flex-tube or as a straight-tube blower. It is now a discontinued model.
one of the prongs came off
is there any way to replace it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
nishonijewelry , could not find the plug in a part listing, every body wants to sell the hole blower unit.
Are you feeling handy. You could have unit disassembled and have a pig tail and plug added. It would take a little ingenuity but can be done if you would like to go that wrought. Just make sure cord is attached/ fastened in body securely and can not be yanked out of housing.
Hardware store should have all required parts. 2 feet of 14-2 extension cord, 1 heavy duty male plug(if existing was 3 blade/terminal, replacement should be 3 blade) and a cable clamp or 2 that will work to secure wire from being pulled out of body of blower. You may also need 3 female spade terminals to clamp on wire to make the connection back on switch/motor. Link below is just to give a visual of what I am talking about. Good luck.
https://www.youtube.com/watch?v=SfdZo8zd...
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
nishonijewelry wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 1,216
