Zum Hauptinhalt wechseln
The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
29 Fragen Alle anzeigen
How to replace plug-in type relay with correct orintation
1999 Cadillac ETC
I have an electronics background, so after my mechanic
keep my car over four months, and then gave up trying
to fix it, i got the prints and started checking it myself.
First thing I noticed is that there are many plug in relays
that have the id of omron 8567, and all these relays have
had the 87a pin cut off, which would allow someone to
plug in backwards. I can't find documentation to show what
the correct orientation should be. Can you help me out?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@bjacount on the Omron 8567 pin87-pin30 and pin85-pin86 are diagonal from each other so that even if you flip it around it still works properly Pin 87a is commonly left disconnected unless it is in a circuit with a sensor.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Very helpful, thank you very much for taking the time to answer.
I don’t recall seeing this situation before. Since there are multiple
Mal-functions, (trunk lid, gas cap, Instrument pnl lights), Going on
when turning on the key, It was easy for me to except the possibility
of a relay being wrong. I may take another look, I do recall an open
ground will do similar things. Thanks Again!
von
I really love my '96 ETC. I would just go to a parts store, take the relay, buy a new one and ask why anyone would cut a pin. Looks to me like orientation may or may not be an issue (there is a lot of confusion on the web posts) . If you tell me where to locate the ones you are looking at, I can go look at mine, shot a photo if need be and give you a better answer.
Bewertung 2
1 Kommentar:
Thank You for your reply! Yes, this has been one of the most enjoyable cars for us also to own.
von
Antwort hinzufügen
bj bowles wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 1,132
