but the screen is black
Please help, My Laptop (Toshiba Satellite L75D) turns on, indicator lights on, fan is running, but the screen is black. I tried all the instructions but nothing worked. Any idea how to fix this?
Ist dies eine gute Frage?
first you must do some tests before like changing the ram connect to external lcd then i will told you
War diese Antwort hilfreich?
Hey, as the previous commenter suggests, if your laptop supports external display you can plug it into a monitor or a TV to at least see if its the Graphics chip OR the screen itself that's flaking out on you.
If the display (HDMI/VGA/Display Port etc) sends a signal to the external display you have a problem with the LED/LCD in the laptop.
If you don't, then there is likely a good chance the issue is with your graphics chip, or something else.
I've seen the display issue being anything from a kinked cable, to a blown backlight. Most times its approximately $100-150 fix depending on where you source the parts, and who puts it in. (I've seen big box stores charge upwards of $300-600 depending on screen size)
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 113
1 Kommentar
Hi, Try connecting an external monitor and see if there is a display on it.
von jayeff
