Zum Hauptinhalt wechseln
How can you replace the battery in a HyperMac/HyperJuice battery pack
Hello, I have one of the first models of the HyperMac (HyperJuice) battery packs.
Model: MBP-100
HyperMac External Power for MacBook version 1
Rated 14.5V-18.5V (4.5A Max) 100Wh
It is not holding a charge for that long anymore and I want to know if anyone has successfully replaced the batteries inside?
The warranty is long past and I'm willing to ignore the Do not disassemble notice.
I asked Sanho if they can do it, but they said that it isn't replaceable.
But I'm not really wanting to toss this out just yet as the circuitry is working just fine.
Cheers and thanks!
Ist dies eine gute Frage?
Bewertung 0
7 Kommentare:
Just wondering if anyone has tried this yet?
von
I have 2 150's that have been dead for a couple years. Hyper has lost my business for future batteries due to this problem.
von
Did you have any luck with this? I've purchased some 18650 batteries and stupidly didn't take a photo of how the batteries were setup before disconnecting them. If anyone's able to take a photo of the internal battery tray it'd be much appreciated,
von
@rhodesy22 did you ever get the batteries figured out?
How did you get into the case?
can you provide a bit more information on the batteries that you bought? Pictures and where from and how much?
If you can do this for me then I can try to venture into mine and see if we can figure this out together if you haven't already.
Cheers, @skippingrock
von
Hi. To get into the case there’s four screws, two on each corner. Then there’s a sticker in the middle on one of the long sides. This screw holds the battery pack in place. Remove the sticker and take that screw out (five screws total). I’m about to attempt to repair mine. I really hate this company, bought this in 2015, used it maybe twice, died about a year later. Always wanted to fix it but never had time, now I’ve got time. These look like vape batteries. Are they 18650s? Should be easy to fix this if they are.
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
3 Antworten
Here’s a diagram I just made of the battery layout
Mine is the MBP2-100 (controller board says V2)
I asked the company (Sanho) for help and they ignored me
Information about the batteries:
Brand:LG
Model:LGDAS31865 (ICR18650S3)
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1075mA Standard
2150mA Maximum
Discharging:3.00V Cutoff
430mA Standard
3225mA Maximum
Description:Blue Cell Wrapper
White Insulator Ring
18650 Form Factor
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
hello @ Xrgsz how did the rest of your attempt to fix this go… did it work for you?
von
I did eventually figure out one or more of the batteries are dead.  What I did was I used a nitecore charger that is designed to get the chemistry going again in dead batteries and it got up to 98%.
I charged them in fours. So I had to do this three times.
 As far as replacing the batteries yourself, the problem is that they’re welded, and doing spot welding on 18650 batteries with nickel tabs at home isn’t exactly ideal, especially if you don’t know what you’re doing.  They (Sanho) offered to sell me a new battery, like JUST the battery, not the case and the controller board, but the price they wanted was obscene.  I opted not to go that route.  I was trying to figure out some other way of connecting the batteries to eachother but I came up empty unless you get batteries with the nickel tabs already welded onto them, and then you can just solder wires to the tabs, but even then, that has to be done very carefully, and the batteries have to be discharged first.  You can get those “project tab” batteries on eBay and other sites, but they tend to be more
Bewertung 0
2 Kommentare:
@nick What nitecore charger did you use? When you used it, did they hold charge again? I had a battery repair store where I used to live and they did the proper spot welding to replace the batteries in another device of mine, too bad I didn't think of taking it to them before I moved. Haven't found a similar store in my new area. The stores here are just glorified retail stores without any electronics know-how.
So for yours, does the battery back now back up using the built in charger or do you have to keep using the nitecore now?
von
@skippingrock Wrong nick?
von
Hi ! Is this still active ?
I have the same case, I’ve used the MBP2-100 quite many years on & off, bow as I pulled it out again it was dead. just as people above say. Nothing happens with just batteries, but seems to work when connected to DC in.
So it could be the 18650 cells, need to do a bit of measuring, but if there’s a cell that’s totally out, I guess the battery management disconnects the battery altogether.
Bewertung 0
Antwort hinzufügen
SkipR wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 912
