Why does my wifi signal keep dropping?
Sometimes I can connect to wifi, and when I do it automatically drops the connection.
Ist dies eine gute Frage?
First and foremost, make sure that the wifi is turned on and connected on your device, this can sometimes be looked over. Also a simple solution can be to unplug and restart your router, many times this can cause the problem to go away. If that doesn’t work, go to your search box and type Network Adapters, under that select update driver software. Once it is done your problem should be solved, if you are still experiencing issues please check out this link Dell Inspiron 11-3162 Troubleshooting.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 521
1 Kommentar
It drops the connections or the signal automatically drops and do you use windows 10 ? ?
von Loukas
