Zum Hauptinhalt wechseln
Fahrenheit FHT 125PRMR flatiron uses heat to straighten hair between two ceramic plates. The device can be used to straighten, curl, or wave flip your hair.
3 Fragen Alle anzeigen
The temperature dial won't turn.
The temperature dial is stuck and does not turn. The temperature of the Fahrenheit FHT flatiron will not change when it is powered on. How do I get the dial to rotate so I can adjust the temperature?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Always proof read your question before posting. Is it stick or stuck? What is Fahrenheit FHT? What is a Fahrenheit FHT 125PRMR?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hello MeKenzie,
If the dial on the device is stuck this may be caused by a sticky substance building up around or under the dial. The first step would be to take a cleaning agent and anything that could fit under and around the edges of the dial and try to clean as much of the substances as you can. If it is still stuck then please refer to our troubleshooting page for a more technical solution.
www.ifixit.com/Wiki/Fahreheit_FHT_125PRMR_Troubleshooting
War diese Antwort hilfreich?
Bewertung 0
Hello,
If the dial is stuck it could be due to how it was the dial itself is seated. Please look at this troubleshooting page to find information on removal/replacement and proper seating of the dial.
Fahrenheit FHT 125PRMR Troubleshooting
Bewertung 0
Antwort hinzufügen
MeKenzie Hilsmeyer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 225
