Why I have lines on display
Why Iphone 5c has floating lines all across display, the rest is working fine
Ist dies eine gute Frage?
sounds like a connector problem if its not the lcd
War diese Antwort hilfreich?
Turn the phone off, disconnect the battery and disconnect the lcd and digitizer cables. Reconnect the lcd and digitizer cables firmly, then the battery and turn it back on. If the problem is still there, it's probably a faulty lcd. I have fixed hundreds of iPhone 5c's and run into this issue every now and then.
Thanks Brian, Thanks James, it worked.
Luckily, I do not need new lcd. After reconnecting cables all back to normal
You're welcome. Im glad that worked for you.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 63
1 Kommentar
Anything happened that may contribute to that issue prior to it happening?
von Ben
