Zum Hauptinhalt wechseln
A1708 / EMC 2978 - Dieses MacBook wurde Oktober 2016 als Einsteigermodell seiner Klasse eingeführt. Es kommt mit den klassischen Funktionstasten, sowie zwei Thunderbolt 3 Anschlüssen und einem Intel Core i5 Prozessor.
Can the SSD be switched out?
Can the SSD be switched out and upgraded ?
Ist dies eine gute Frage?
Bewertung 8
Einen Kommentar hinzufügen
7 Antworten
Hilfreichste Antwort
Looks like the entry level 13" isn't soldered
OWC noted the following points in its teardown.
– Bottom was more difficult to remove than previous generations, but it was not glued.
– Speaker module needs to be removed to pull SSD back.
– SSD had very strong tape covering the interface port.
– Laptop automatically turns on when you open it regardless of pressing power button.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
If you review the OWC vid you'll also see the SSD module is very different from the older systems and it looks like a custom part! So, even if its removable, it will be a while before we see a 3rd party option.
von
@danj Yes I saw that! Hopefully the wait isn't as long as it was for the Retina models!
von
http://blog.macsales.com/38440-ssd-in-la...
Bewertung 1
Yes, Please look at
Bewertung 1
Yes. But so far no one has made an SSD that is compatible with this model, the first few will begin to pop-up within the next few months.
Bewertung 1
Yes is it removable.
Update (10/31/2016)
Bewertung 0
2 Kommentare:
Do you have a back up link on this?
von
I would like to know where you got this information. Nothing on the internet says Soldered, but I wouldn't put it past them
von
Anyone here who knows the pinout of the new SSD?
Bewertung 0
Adapter for MacBook Pro 13” 2016/2017 nTB
https://www.globalmac.cl/Adaptador-SSD-M...
(Chile)
Bewertung 0
Antwort hinzufügen
benkuza wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 27
Insgesamt: 8,128
