Zum Hauptinhalt wechseln
Modell A1419 / EMC 2806 / Ende 2014 oder Mitte 2015. 3.3 oder 3.5 GHz Core i5 oder 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 Ende 2015 / 3.3 oder 3.5 GHz Core i5 oder 4.0 GHz Core i7 (iMac17,1) alle mit Retina 5K Displays
573 Fragen Alle anzeigen
iMac Late 2015 - Upgrade SSD or use Apple Stock SSD
When buying the 1TB SSD with the iMac directly from Apple: Is it a PCI-Express SSD then?
Is the main HDD-Slot empty in this case (hence could I add another HDD later on?)
Doing the upgrade via Apple is like 400$ more expensive than upgrading yourself. Is the PCI Express SSD worth it? (If this is what apple uses)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Your system has two drive ports: a custom PCIe x4 for a blade SSD and a SATA III (6.0 Gb's) for a traditional 3.5" HD.
If you review the IFIXIT teardown here: iMac Intel 27" Retina 5K Display Teardown you can see whats what.
War diese Antwort hilfreich?
Bewertung 4
8 Kommentare:
Yeah okay, I see. So if I buy the 1TB SSD, only the blade slot is used and the other one is blank?
von
Apple also sticks it to you on the RAM, so upgrade that yourself too.
von
Yes, the SATA port for the HD would be available for a future drive. It could even be a 2'5" SATA based SSD!
von
Do I need the thermal sensor ($37) for a Samsung SSD Sata that I'm gonna replace the HDD with on a late 2015 5k imac 27". I'm buying the bracket, adhesives with wheel cutter, do I need to buy OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade??? I read that with sierra and el cap I wouldn't need the sensor. I wonder though, if I had to boot into windows (i have yet to need to, but may have work that will benefit from it), if the fan would go full blast.
von
Nope, Apple didn't alter anything within the OS or firmware to forgo the sensor. I think you're getting caught up in an urban legend.
Yes, you still need the in-line sensor, here's the part you'll need: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
Max wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,390
