I had the same issue for quite a while ... I believe I found that it's the "Knock On" feature of the phone causing the problem. If the LG G4 is tapped twice while sleeping, it wakes. On the LG G3 that setting could be turned on/off, but on the LG G4, that setting is not made available.
I think that the accelerometer in the phone, or something in that Knock On feature that monitors the accelerometer, has gotten way too sensitive in one of the phone updates. Now that I've turned off that feature, my phone stays dark and quite, as it should after I put it to sleep.
There's an app in Play Store called QuickShortcutMaker that can be used to make a shortcut to the hidden Knock On setting. After installing, while looking at "Activities", type "Knock On" in search. Settings should show up in the list underneath. Select the down-arrow next to Settings, and a couple sub-settings will appear. They should be "Knock On" type settings and you can choose either one, they both do the same thing. Select one of them, then change the name from Settings to "Knock On" for the shortcut you're going to create, and you can choose a different Icon for it. At the bottom, create the short cut, then find it on your display and select it. Or just select the "Try" in the QuickShortcutMaker to open the Knock On setting and disable it.
Here's a link to where I found this information: https://www.phonearena.com/news/How-to-d...
LG G4, may you sleep long until needed.
Hope this helps!
BabbleBits
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
5 Kommentare
Hi, Did you update the phone or install any new apps just before the problem started?
von jayeff
No nothing no update no new apps but here is one thing when i plug it to charger the problem goes away
von ilyass bouzid
hi, It's beginning to sound like a battery problem. Just wondering if you charge the battery to 100%, remove the charger and see if it happens then or if it only happens when battery is at a lower %.
You may already be doing these things and it has nothing to do with your problem but every little bit helps. This link explains ways of extending the battery life. Hopefully it may be of interest,
http://www.gottabemobile.com/2016/02/15/...
von jayeff
Battery health is good i dont know where the main problem i guess the charger port i guess btw i use samsung charger
von ilyass bouzid
My phone just started doing this two days ago. i turn if off and then 2 mins later my screen turns on. I clean my "power button" with an alcohol wipe. Pushing it as I am cleaning it. It is not the battery as Its news. The more I am cleaning it, the less my phone turns on. Not saying this could be the problem but it helped me. My phone no longer turns on.
von Lisa
