Zum Hauptinhalt wechseln
Why is my backlit of my keyboard always on
my laptop is lenovo ideapad 500 its keyboard backlit won't turn off i checked the bios and updated it nothing worked i checked the lenovo settings app it was saying that it was off but in real it was still the reason why i hate this becuase my battery runs out quickly i would be very thankful if someone told me the problem please please by the way function + space won't work trust me it worked before but now it doesn't
thank you,
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I ended up getting replacement for free becuase my warrantly was still availeble
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
function + spacebar should disable backlit keys.
Bewertung 2
2 Kommentare:
no it doesn't
von
mine is stuck on, also blowing through battery and Fn spacebar does not turn it off like it used to.
von
This is the solution under normal conditions. Did anything else happen to the computer?
Bewertung 1
4 Kommentare:
No it doesn't it worked before but now it doesn't
von
So tell me when this started and what changed with the computer around this time. Installed Windows 10? Spilled water on the keyboard? Installed some questionable downloads? Had to buy a new universal charger? The only way I can possibly help is to know what you noticed that coincided with this issue.
von
i just restarted my laptop becuase of a graphics card update but after the update it was still working then i turned off my laptop and the next day it just wont close
von
I have a Lenovo IdeaPad U430 Touch that I'm working on right now that when up try to turn it on the power button stays lit, keyboard is illuminated, & the white charging light + white power on light (on right side) are lit but display is black (also on but blank). After many hours of searching I discovered it is possibly linked to Graphics Card update. The suggestion was to remove graphics card and then put it back in...I'm about to try this & I'll let you know how it turns out. I've already tried removing the battery and plugging power cord in then holding power button for 30 seconds. That didn't work but I believe your issue and this one are related to graphics card update. Thanks for the additional info.
von
Antwort hinzufügen
amer mohamed wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 5,754
