Zum Hauptinhalt wechseln
This is the Insignia Flex 8, a versatile tablet created by Tianshi Digi-Lando that can connect to the internet, take photographs, and use apps.
How do you replace the charging port?
The charging port in the tablet where you plug in the charger will not hold the charging cable. It appears the prongs may be broken or loose.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
great instructions could not be any better
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Joan, Check if your Flex 8 is under warranty, if you have to have it fixed by a tech., you will have to way your options to whether cost effective to repair, Flex 8 can be had pretty cheap now. I will post a link for tear down on your unit to enable you to access charge port and you can google search for a replacement part. Good luck.
Disassembling Insignia Flex 8 Circuit Board
War diese Antwort hilfreich?
Bewertung 6
Antwort hinzufügen
Joan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 2,631
