Zum Hauptinhalt wechseln
A portable wireless bluetooth speaker introduced in 2013 by Beats by Dr. Dre.
27 Fragen Alle anzeigen
My speaker wont turn off it keeps flashing a red light
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Remove the plastic plate on the end with all the connection ports. I used a very small flat head screwdriver. Once opened, look inside with a flashlight and you'll see a small plug. I used very small needle nose pliers and just unplugged it, waited a few seconds and plugged it back in. Be careful not to damage any of the other parts. This allowed me to turn it off manually. Once you've done this, replace the plastic end piece and you can start from the beginning. This helped me. I certainly hope it solves your issue as well.
War diese Antwort hilfreich?
Bewertung 4
4 Kommentare:
worked it, thanks
von
Absolute legend, thank you so much my freind, worked perfect!
von
You are the Legend, mate!
von
it's worth really thanks a lot. your genius
von
Brilliant - mine had frozen in on position but not reacting to any of the buttons, took your advice and all spot on again - top man!
Bewertung 0
1 Kommentar:
Thank you this also helped me
von
Antwort hinzufügen
Rumbi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 7,178
