Zum Hauptinhalt wechseln
The G3 Controller is gamestop's version of a gamecube controller, equipped with A, X, Y, Z, B, Turbo Button, joystick, C-stick, left and right triggers, and a directional pad.
Why is my controller moving the character when I am not
My controller causes my character to move when I do not move the control stick. Is it dirty or is it just a bad signal?
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Turns out there was an error when the console recognized the controller so I just unplugged it and re-connected it to the console.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Often times, disconnecting the controller and blowing into the connection port on both the controller and console can fix this problem.
War diese Antwort hilfreich?
Bewertung 1
Bewertung 0
It may be dirty or your joystick may be misaligned. I recommend you check out our joystick replacement guide, and use the steps to clean out the area and then reattach your joystick. If the problem still persists it may be a problem with your motherboard.
Bewertung 0
Antwort hinzufügen
Andrew Gonsalves wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 39
Insgesamt: 634
