Why is my Nissan Altima 2.5s smoking
After changing the spark plugs and replacing new engine oil I found out that my car has been smoking profusely since then what could be the cause and the solution. Thanks
Ist dies eine gute Frage?
if you have not changed the oil in a very long time causing a build up of dirt on the rings and causing them to wear . When you put new oil in this cleaned the rings and now with the wear its letting oil pass the rings and this causes the smoke. Or you could have used the wrong oil . Make sure you used the proper weight oil .
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 2,316
