Zum Hauptinhalt wechseln
Dell Latitude D630 is a thin and lightweight version of the Latitude line. With a 14.1 LCD screen and a 9 cell battery, this laptop is meant to be more mobile.
Restart Dell latitude d630c
How do I restart it and why is the orange light blinking
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
This question was migrated from http://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
A blinking orange battery light indicates a failing or discharged battery.
What indications do you get when you connect the charger?
Is the light continuous or flashing?
If it is continuous allow the battery to fully charge and then try switching it on.
If it is still flashing, remove the battery from the laptop and then connect the charger and see if it will start.
If it does, then perhaps your battery is failing and needs to be replaced. Even rechargeable batteries have a life span.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Rick Farley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 54
