Zum Hauptinhalt wechseln
The Coolpix P530 is a 16.1 megapixel digital camera with an impressive 42x optical zoom. This model was released by Nikon in February of 2014. It also goes by the manufacturer specific model name Nikon 26464 .
20 Fragen Alle anzeigen
What is this flashing red square with possibly a clock symbol?
A red flashing symbol is flashing (it's right over the battery symbol). I do not know what it is so I do not know how to fix it to stop it from flashing. Can you please help me in fixing this problem? It's a red square with what looks like a white circle resembling a clock with a 9:00 read out and has another dot where the 3 would be.
I'm expected to take a trip in the next week and really need my camera. Thank you for any help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 12
3 Kommentare
I also encountered the same issue , the first answer was perfect as it is related to time zone setting. Once you manage that by getting it correct in your camera settings, issue get resolve the then and there only.
von
Thank you so much, it worked it was the "Time Zone Setting" but why is it not in the Manual?
von
Thanks. It worked well
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The date and time are not set on your camera. Using your camera's menu, try setting the date and time on the camera. If you can't figure it out, look up your camera's manual online and read about how to do it.
War diese Antwort hilfreich?
Bewertung 15
4 Kommentare:
Very helpful. Sort of obvious in retrospect. But hadn't figured it out. Thanks.
von
Thank you!!!!
von
Did that it says failure to link to satellite.
von
Thanks so much! Flashing icon disappeared when I set time zone and date. This was driving me crazy and was NOT mentioned in 147 page owners guide! You are my hero :)
von
It refers to the time zone setting. My daughter just showed me!
Bewertung 5
2 Kommentare:
What she said ^
I
von
It means you need to go to the menu and set the date.
von
Sorry if this doesn't help but I'm not quite sure what this mean but on some cameras it might mean that the flash is on that the camera is dying, try charging it.
~Hope this helps!
Bewertung 0
Antwort hinzufügen
Janice Rogers wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 34
Letzten 7 Tage: 260
Letzten 30 Tage: 1,273
Insgesamt: 59,017
