Zum Hauptinhalt wechseln
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211 Fragen Alle anzeigen
Does anyone know the internal components of Samsung Galaxy Note 2?
Looking for a complete tear down of internal components. Have an old galaxy phone that I want to harvest parts from.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
as in a schematic ? Or are you looking for a tear down of the note?
von
Big thanks to both of you. This gets me started! The reason I am asking is because I had a project in mind and I would like to use the Samsung smartphone hardware as a starting point. I couldn't find a forum and where with the sort of information I was looking for and this is as close as I got so far. What I really wanted to know was exactly what you provided. Basically I wanted to know which components were which. This will enable me to research the rest of my own.
von
Again thanks to both of you! Have you ever played around with the hardware? I don't need the actual phone functions at the moment, just looking for a small package processor that is already proven and will already run android without too much programming know how.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@pjax258 Just like @jimfixer pointed out, you have to be clear about what you are looking for. If you are looking for a description of the components on the circuit board, then you are in for a lot of work. Let me show you why:
Samsung Galaxy Note II is known as a GT-N7100 and here is the layout from this area only.
and then you are looking at the board layout with the reference designator of the components
Samsung is not very nice, they do not mark the components for the specificity. We know L being an inductor, C capacitor etc. but there are no values. For that you will need the part list. Let's pick one. Lets say L300.
So here is a view of the parts list
Okay at least we figured out that L300 is the same as L301 and L512. Samsung part number is 3301-001956 and the description is BLM21PG220SN1D. Nice, but still no values. You will have to use the description not the Samsung part number) and your favorite online search engine to determine that it is a 22Ohm 6A 25% Ferrite Bead (inductor,choke etc.) So, as you can see there is no easy way to give you a list for all this. It is tedious and cumbersome. Now that was fun to answer.
War diese Antwort hilfreich?
Bewertung 2
Hilfreichste Antwort
This may be of some use but it is not a Schematic
Hope this helps
Bewertung 3
Antwort hinzufügen
Pablo Picasso wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 578
