Zum Hauptinhalt wechseln
Pilot not holding Goes out after let go the button.
Hello... trouble with the water heater.
First the pilot wouldn't lite.. so i turned it off for 10min to clear the gas and tried
it again and the pilot worked. I hold the pilot button down until the status flashes but
the pilot goes out when i let go the button. I was told there is a reset button so i pushed what i thought was the reset but it doesn't push or click. Any thoughts?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Tested the Thermopile and the mV reaches above 500 mV and continues to go up after about a minute of holding down the pilot button, but as soon as you let it go it drops back down to almost nothing.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@cameraparts4you , Be extremelly careful working with your gas appliance, if unsure contact a Qualified Technician. Dirty TC( thermocouple), faulty TC, pilot flame to not set properly/small or not close enough to TC, partially plugged pilot tube, faulty/bad gas control valve, all could cause pilot not to stay lit. Check the attached links troubleshooting,instruction, Good luck.
http://www.doityourself.com/stry/reasons...
http://www.home-repair-central.com/gas-h...
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
Sales Cameraparts4you wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 92
Insgesamt: 23,731
