Zum Hauptinhalt wechseln
Veröffentlicht im Juni 2009 / 2,53 GHz Core 2 Duo Prozessor
170 Fragen Alle anzeigen
MacBookPro- How to remove damaged screws mounting the HDD n its Cable?
Hi! There. I've got a Macbook Pro 15" Mid 2009 Model. The screws inside of my Mac which mount the Hard Drive n support it as well as the screws which fix the HDD Cable to the body are damaged. They are Phillips screws, but because of my previous trials to unscrew them with some unfitting screwdrivers the cross on the head of the screws are damaged and in one of them it has become almost a rounded pit, so none of the screwdrivers fit in to it, anymore. I have attached the pictures of them below. Please help me with this problem and please reply me if you have some solutions for the same.
Thank You.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
At this point I would take it to a professional. It appears that whoever worked on this machine lifts to much weight and uses to heavy a hand to work on delicate parts.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I think the OP will need an easy-out to remove these +
von
Thanx man, I appreciate your help and sorry for replying you so late.
von
Some Screws seem that it can be removed by a Bigger Philips screw driver to get the adequate grip ...or else you may use a screw remover tool to remove the same . You may purchase it on the internet or at the local hardware store.
Hope this Helps.
Bewertung 0
1 Kommentar:
von
Antwort hinzufügen
Dipen Ponkia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 1,616
