Need a diagram of 91 chevy c1500 steering column
Steering wheel is very loose . Took it apart and tightened it up and put back . Wll not go back together. Would like a diagram of steering column.
Ist dies eine gute Frage?
kpgklm, The links below will show exploded view and vids on steering column to aide in your repair. Check the attached links,instruction and guides, Good luck.
http://www.steeringcolumnservices.com/ex...
War diese Antwort hilfreich?
L Pfaff came thru with flying colors.. Very fast response with the info I needed. Thank you so much ! Still good people around !
kpgklm, thanks for the response, if it was the answer you needed vote it up, Thanks.
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 54
Insgesamt: 15,501
1 Kommentar
Make sure bearing is assembled properly just behind steering wheel
von p_buchwald
