DC-in female plug for AC adapter broken - can this be replaced?
Battery isn't receiving a charge, and the area around the plug is cracked as well. Battery btw is brand new, but is slowly losing its charge.
Ist dies eine gute Frage?
Here's the part: [verlinktes Produkt fehlt oder ist deaktiviert: IF133-010]
Here's how to install it: PowerBook G4 Titanium DVI DC-In Board Replacement
War diese Antwort hilfreich?
good answer +
The Onyx is not the DVI model though...only the DVI model has a removable DC-in. Pinarello99, does your machine have a DVI port on the back, or a VGA port? If it's a VGA port, you will not be able to replace the DC-in, but if it has a DVI port, you'll be able to use the part that Mayer suggests.
Unfortunately the non-DVI Titaniums have an integrated DC-in, which means that when the DC-in is broken or problematic, you have to replace the whole board.
Titaniums are definitely a pain to work on, so to replace the board (because the Onyx has an integrated DC-in), you're looking at spending a few hours on it, especially if you've never done it before.
Honestly, this machine doesn't really have much of a monetary value at this point, so to specifically buy a working and tested board for it is silly, especially at the $100+ prices you'll find, as you can buy a fully working machine for less. As I always say, the best source of parts is a broken laptop, so I would search eBay for a working Onyx with a smashed screen...who knows, you might be able to pick one up for $20. Find the model number of your machine on the underside (probably something like M5884), and search eBay for it that way. But like I mentioned, you're in for an interesting experience -- click on the "Repair" button, the click on "PowerBook", then "G4 Titanium", then "Onyx", then "Logic Board" to see the guide.
+ If an Onyx, this is a much better answer than mine and rdkl knows a lot more about this machine than I do. Look for him on eBay for a good replacement machine.
This Powerbook is definitely Onyx - rdklinc, if you have info re replacing the board (if doing so is not a gigantic hassle), I would appreciate that - also where I could find the part (even the best keywords to use for an ebay search will do in a pinch)
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 2,054
