Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
The battery refuses to charge after a replaced it.
I just replaced the battery on my iPhone 6. It is refusing to charge more than 8%. Does anyone know what might be causing the problem and how I could fix this? My phone is also heating up a lot, if that has anything to do with it.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Why did you change the battery? Was it also not charging or holding it's charge?
Did you remove the screen assembly when you changed your battery?
A lot of things could have gone wrong here but first we need to know what happened leading up to your reason for posting.
von
No the battery was fine, the volume switches got stuck and I had to take the battery out to replace them. Then I screwed up the battery and needed to replace it. I did remove the screen assembly when I was getting to the volume buttons.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
could be Tristar failure. Seek out a qualified professional in your area who can diagnose battery, tristar, or install.
War diese Antwort hilfreich?
Bewertung 2
Hilfreichste Antwort
probably a sucky battery, and remember to replace the adhesive.
Bewertung 2
Antwort hinzufügen
Lauren May wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 73
