Screen issue goes black or very dark
Screen goes black or very dark. If you take a picture, pic will be the same. Is this a bad screen or mother board failure?
Ist dies eine gute Frage?
Hi,
if the picture is dark as well as the LCD screen most likely the problem is that the ccd sensor is faulty.
Here is a link to the Ifixit guide which will give you access to the sensor.
Canon PowerShot SX260 HS Motherboard Replacement
Here is a link to just one supplier of the Lens Unit assembly including the ccd sensor. There are others which may suit you better. It is only shown to give you an idea of the cost.
War diese Antwort hilfreich?
My sx260 has screen black and photo black that is intermittent and follows pressing on the round mode selector dial on the back. When it goes black I can make it come back by putting slight pressure on that dial. I don't know where the pressure on the dial is acting to solve the issue. It could be a connection there or someplace else. I understand that this is a not uncommon issue. I have used this camera so little over the years. It has lived in a desk drawer. So this problem seems to be defect in the camera.
I had the same issue you are describing. What I did was remove the back plate by removing five of the screws from the above guide leaving the screw on the bottom of the camera for the front case, this made holding the camera easier so it wouldn't fall apart. I then removed the ribbon cable for the selector knob, its the only cable coming from the back case. I then cleaned the contact of the cable with IPA and initial testing is promising, I can use the dial without the screen blacking out.
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 34
Insgesamt: 1,799
