Zum Hauptinhalt wechseln
The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
Shaky/swervey/pulls left and right
Feeling a shake in the floorboard and in the steering wheel.
When I'm traveling and go to switch lanes to pass, it get squirrel lee. and will throwing into other lane if not careful.
It will pull to the left sometimes and then pull to the right sometimes. Go figure.
Hope I've been helpful.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
Also check your wheel alignment and wheel balance.
Look at the tread wear in the front tyres to see if the tyre is being worn evenly across the face of the tyre
War diese Antwort hilfreich?
Bewertung 2
Check your tie rods. A lot of times when they are worn they will allow for more than desired play.
Also check the ball joints.
Bewertung 1
Antwort hinzufügen
Rickey skipper wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 39
Insgesamt: 357
