How to connect tablet to TV
What type of cable is needed to connect the tablet to a TV? HMDI from tablet to TV results in "signal not found". (Yes, the TV is set to HMDI for input). Thank you for your help.
Ist dies eine gute Frage?
Are you using the HDMI port on the device itself? It could be a Micro or Mini HDMI.
War diese Antwort hilfreich?
Yes HDMI cord w mini adapter connected to rca tablet ,TV screen says " no device found" , what other options are there
On your RCA tablet go to settings, click on display and then configure HDMI settings.
What do you do after or even how do you configure HDMI settings
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 13,074
6 Kommentare
I am using the HDMI port on both the TV and tablet. Tablet takes a mini.
von boogityboo
I now have it working. Started it with the keyboard attached, then removed the keyboard. Thanks for the help.
von boogityboo
cant get it to work either way.what to do ?
von Wess Reddish
I am having the same problem, HDMI cable is connected but tv says no signal. Did you find a soloution?
von jillherbert1
I've got it working, see my answer below.
von jillherbert1
1 weiteren Kommentar anzeigen
