Zum Hauptinhalt wechseln
Model CUH-ZCT1. Dieser Sechsachsen-Controller mit dem 3,7 V Lithium Akku, den Sony im November 2013 auf den Markt brachte, ist leicht zu reparieren. (BEACHTE: Die Teardown-Anleitung ist NICHT für dieses Modell)
The square button is not work
The square button when I press on button is not work what I do
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 10
2 Kommentare
you can replace the square button. you can order the motherboard from the IFIXIT site. and you can see how to fix also on this site.
von
Yo no lie all I just did was get some scissors and pull up tried to wedge it in the side and just keep doing that trying to take the square button out than just pull up Spotify and keep trying use square till it work I swear try it
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Hi Amjad!
You can find our repair guides here for fixing or replacing the buttons on this controller:
DualShock 4 (CUH-ZCT1U) Tasten tauschen
We also sell replacement parts for the controller if you need them. These are the buttons:
DualShock 4 Controller Action Button Covers
Includes the plastic action button covers and the button gasket Bild
Produkt
War diese Antwort hilfreich?
Bewertung 4
Make sure to clean the connection to from the conductive film to the motherboard.
https://youtu.be/Lx3La8a169Q
Bewertung 2
Thanks on the bottom of the phones keyboard, the square button doesn't work. How do I get it back working?
Bewertung 1
1 Kommentar:
How to make this work
von
I was having issues with my left analog stick constantly drifting. Took the controller apart and cleaned it. Now it works great……except the square button doesn't work now. I'm thinking it's the clear film. May have a tear but I can't tell. Hope that info helps someone. Still working on my square button. Thinking about buying another mother board.
Bewertung 1
1 Kommentar:
I did same thing as Jason above, took controller apart cleaned it thoroughly put back together and square button not working.
von
Exact same thing happened to me cleaned joysticks sensors and now square button doesn’t respond, I can see and feel it makes contact but no response I was thinking it was the ribbon strip because a couple of connections on the ribbon were folded back from disconnecting and reconnecting so many times maybe this could be the issue?
Bewertung 0
Antwort hinzufügen
Amjad Badkook wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 108
Insgesamt: 87,961
