Ipad wont charge after screen replace
The ipad turns on after i replaced the logic board but when i go to plug in the charger it will not charge. Help would be great please.
Ist dies eine gute Frage?
Not so many things I would point you to..double check charger, charging cable and then charging port and the connecting flat cable to the logic board and relevant connector..It might be just a small thing, little bad luck.
If all those parts work properly, there's only the logic board left with its charging IC...are you 100% sure it was working perfectly before install ?
War diese Antwort hilfreich?
Yes it was working perfectly before install. When i disassembled the ipad mini i noticed the charge port cable was not connected to the logic board. I dont know if i have to order another logic board with the connector on it or what should i do in regards to this situation
Isn't the charging port connector soldered onto the board for connection? That requires soldering to do.
It was when i got the logic board but i also noticed that the charging port connector was all beat up and the pins were bent on the inside. Should i order a new logic board with a way better connector attached to it or what should i do.
Unless you got someone in your area who does microsoldering jobs, it sounds like you need a new logic board with a proper charging port attached, yes, no other alternative unfortunately.
Yes i need a new logic board with a new charger attached to it will solve my problem
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 84
