Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone 6 has random restart problem after 10.2 update
I have a iPhone 6 that started having random resets after the 10.2 update. Phone was fine before update with no reboot problems. Went thru trouble shooting with crabapple support and went thru all thier trouble shooting steps.
Final step was torestored the phone in recovery mode and setup as new phone. This did not fix the problem. Apple refused to admit the software ware could be the problem. From info I have found others are reporting the same rebooting issue with thier iPhone 6. Of course apple said I could buy a new phone as this one Is 30 days out of warranty.
Anyone have any suggestions to fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I have been seeing this a lot in my shop the past week... A new battery seems to be the only reliable fix.
War diese Antwort hilfreich?
Bewertung 5
2 Kommentare:
Apple strikes again with planned obsolescence through iOS updates!
von
What rneely is saying, use a good quality battery (I highly recommend iFixit's) and if this issue remains after wards, back-up, restore from DFU, then restore your data. The longer you wait, the less likely you are to get your data back in case you haven't back-up yet.
von
The fix was replacing the battery. Apple needs to extend battery replacement to the 6. The software test apple uses to test the battery is not accurate. Replaced battery 1 week ago and 0 resets. Kid at Birmingham Genius Bar and manager acted like a jack$$$. Arregont.
Bewertung 0
hi my iphone se is randomly restart and it happend all of the sudden . sometimes screen goes with noisy black & white colors and turn of its like freezing or hang and i should do the hard reset to turn it on.i restored it over itunes and dfu mode .i using ios 10.2.1. any help?
Bewertung 0
Antwort hinzufügen
scottingram wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 11,929
