My laptop shutdown in every 30 to 40 minutes
my laptop shutdown in every 30 to 40 minutes and when i try to start again blue screen apear and system restart after trying 3 or 5 times its start
Ist dies eine gute Frage?
@valvi31, nitin , Could be overheating. Use the link below, a guide to dismantle your laptop so you can clean your computer inside. The fans and board may have accumulated a lot of dust, not allowing heat to dissipate properly causing it to over heat and shut down, the 3rd and 4th link will show how to clean. Good luck.
https://www.youtube.com/watch?v=c8HU06L4...
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 296
1 Kommentar
It could be a thermal issue with the CPU, the laptop will shut down if it detects overheat problems. It also could indicate that the thermal detection has gotten too sensitive which would indicate a bad mother board.
von DrGlowire
