Zum Hauptinhalt wechseln
The front burner will not turn off sometimes
I have a glasstop range and sometimes when I try to turn down the heat under a pot,
it does not turn down and sometimes takes several attempts to shut the burner off.
It just stays on very high temp
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Two Possible Problems: Your burner's gas valve has worn out and it leaks. It needs to be replaced. A leaky gas valve is a fire hazard. Or, the connector from the burner knob to the valve control has weakened. The plastic is in a shape that does not fully operate the valve. Both of these problems are easily replaceable.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Betty wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 17
