hi washing machine faults out on OE error .
hi i have checked the drain hose , cleared the filter , and also checked the pump is spinning freely . issue isnt present during mid cycle . water is draining during wash but near the end of the cycle the drain issue becomes apparent and it faults on the OE code .
Ist dies eine gute Frage?
10 Kommentare
hi i have same front loader i have 3 lines showing where the time of cycle should view.
von lukey_lover
Just to add to this I took mine apart and just cleaned the pump and it has been working for a year-and-a-half since. The pump basically has no moving Parts it's a magnetic impeller mounted in a housing. Took it apart cleaned it I threw a little bit of a light oil where the shaft of the impeller sits in the pump housing. Don't waste your money on buying a new pump if your pump is trying to pump and it can't it's probably just a dirty impeller. Very easy fix and it was free!
von Snowdogkh
My machine shows t lc
wat does that mean it’s not in booklet
von Farzana patel
LG smart drum being DUMB.
IT'S not making connection to pump on draining cycle?
What else could be happening,
I replaced with new pumps
2 x ,everything works if I lay hose on floor on draining cycle. Can my main board be damage? Or can I replace a contact or something?
von Rafael Martinez
I had the same problem with oe code, took machine apart nothing in pump or hose, no filter on my top load model, so I tested the water fill valve by unplugging the machine while it was filling and it did not stop flowing water. Ordered the water fill valve assenbly for 32.00 replaced it in 10 minutes and my machine runs like a new one with no code!
von Adam Gibson
5 weitere Kommentare anzeigen
