Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s Plus gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1041 Fragen Alle anzeigen
Issues after housing replacement
I changed the housing along with a new lcd on my iPhone 6s plus.
When I turn it on. It sometimes works and sometimes doesn't prompting the plug in charger icon. But oddly it will actually turn on sometimes and after a 10 - 20 seconds will shutdown with no notice.
Does this mean the battery has been damaged during housing replacement.
Secondly the antenna on the top left wasn't coming off as I didn't know about the hidden screw under sticker and I ripped it off.
Now the little plate on the back has broken off but I sandwiched it back and screwed it down. Should I replace with new one?
Update (01/03/2017)
ok switched battery and now problem solved.
i have a new issue now. The volume button randomly presses itself especially the vibrate rocker? does the flex for volume need to be changed?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
original flex solved issue and it seems i had battery issue too. now all is working fine
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Housing replacements are, oddly, more tricky than it sounds. The first problem could be a bad battery. The second problem sounds like you need to replace it with a new one for sure
I know you probably have figured this out. But I'll post a guide, just in case
This is the antennae in the top left
Bewertung 1
1 Kommentar:
they all 6 plus parts buddy. ihave 6s plus
von
Antwort hinzufügen
Obahan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 7
Insgesamt: 112
