Zum Hauptinhalt wechseln
The Stylo 2 (model number LS775), the second iteration of the Stylo series, is manufactured by LG and was originally released in April 2016.
81 Fragen Alle anzeigen
My phone is stuck on configuring phone.
when I first power up it is in the navigation screen for the blind kinda like set up wizard.i answer English then wifi and make sure im connected and as soon as it connects it say configuring phone and will stay that way for days.i cant get past that to set up phone
Ist dies eine gute Frage?
Bewertung 14
6 Kommentare
Go on line to boost and access your account screen and then support and swap out phone or activate phone and enter the serial number and confirm the SIM card number on file for the device. It can't configure til you do that... I misssed the step on one of mine and kept doing that dance until I remembered I'd missed the step. Hope this helps.
von
I had my phone given to me and when its on it says your headphone is configured with an icon of a computer and a charge cord so what do I do now.
von
when i turn on my phone it lets me connect to wifi && after that it stays on configuring phone. it wont go no futher.
von
my hpone is stuck on configuration how do i fix it
von
I had this phone given to me the person that gave me this phone told me the cell phone place told him to do a factory reset on it when he did it got stuck on configure I turned off talk back and held all four buttons and the only thing it wants to skip is the WiFi how long will it configure before I Know it didn't work
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
Hi- i did this instruction and it worked for me
LG LS775
https://www.youtube.com/watch?v=5GdfQQSn...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Worked for me too thanks
von
If its stuck on blind accessibility, hopefully you've taken it back to the store to get them to sort this out for you or gotten a replacement. If you can't do that you'll have to do what I did. The way this feature seems to work is you double tap the screen then select the option by doing a single tap. So when you get to the next screen you double tap and then tap once to crawl through the set up. I'd have gone back to Best Buy but it was evening and a long drive and I wanted to get it done. When you get through, go to settings menu, general and accessibility option and turn it off. I couldn't find a way out of that setting. You can't even do a hard reset (I couldn't) this was a major problem with all 3 phones. It forces you into activate and set up, even if you just bought it to use on wifi. Extremely irritated over this problem. I've read the reviews on Best Buy with this phone and no one mentions this!! And I forgot about it and didn't include it in mine... wondering how prevalent this problem is? It was from jump on mine
Bewertung 0
I followed your steps holding down the volume up & down & the power button simultaniously several times with no success. Then decided to add the home button so holding the 4 keys down at the same time and it worked making the 'Skip' button show up on the configuring your phone page and it completed the process with no further problems. It pauses on that screen when no SIM card is installed. Thanks for your tip.
David Uhrey
Bewertung 0
You got to press the volume buttons over and over intel your phone gos to tbe next stage
Update (01/16/2019)
You got to press the volume buttons over and over intel your phone go's to the next stage or step
Bewertung 0
My phone is stuck on configuring your phone
Bewertung 0
1 Kommentar:
I did that keep showing configuring your phone on screen
von
Antwort hinzufügen
jason barton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 52
Insgesamt: 24,670
