How can I permanently disable wifi from the 2ds
on the 3ds there is an antenna . the 2ds doesn't have it
Ist dies eine gute Frage?
you dont need to cut any cables, you can setup a PIN code to access the options and just delete all the internet connections and set the pin code up so that nobody can access the settings to setup a connection, pretty much the same effect as removing the WIFI antenna..
War diese Antwort hilfreich?
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 1,240
Other answers say parental controls. That solution does not work for me. The child still can call nintendo to disable them..
von Samuel Hilton
