Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Small Blue Tinted Plastic Piece Fell Out While Disassembling iPhone 6
Replaced the digitizer screen successfully on an iPhone 6, however, during reassembly a small blue tinted piece of plastic fell out, and I don't know where it belongs. It is rectangular, has a corner cut off, and has two small holes in it. It is transparent, but tinted blue. It is pretty small, maybe 3 mm long or so. Might this missing piece have anything to do with the fact that the FF camera has a little bit of a halo on the image?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
It sounds like the plastic piece that protects the glue where the microphone sticks on.
War diese Antwort hilfreich?
Bewertung 2
It must have been a leftover piece of protective film from the assembly process. There are not supposed to be any pieces of blue film inside of the iPhone 6.
The halo on your front facing camera likely means there was damage to it or there is some dirt or residue on the glass screen where the opening is.
Bewertung 1
1 Kommentar:
This small piece of blue plastic does not seem like temporary protective film. It looks more like it is designed to insulate one piece from contact with another.
I also doubt there is damage to the camera. Symptoms would be more severe than a slight halo along one edge. Dirt or residue is possible, but unlikely due to the care taken during the repair. Not my first rodeo. fixing these things. My own suspicion is the camera isn't securely back in the camera retaining socket, so it's an alignment or installation issue.
von
For a iPhone 7 plus goes right here.
Bewertung 0
Antwort hinzufügen
gybeho wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 907
