Tub banging on spin cycle
The washing machine on my kenmore 400 the basket when rinsing and spin dry the basket bangs against outer wall.
Ist dies eine gute Frage?
Cause 1
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
Cause 2
Tub Seal and Bearing Kit
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. If the washer is noisy during the spin cycle or is leaking from the bottom of the tub near the transmission, the tub seal and bearing are likely defective. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing the outer tub and bearing at the same time.
Cause 3
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
War diese Antwort hilfreich?
My wife complained of a loud banging during rinse cycle on her Samsung. I removed the rear panel and found that both the shock absorbers were missing their bolts. I replaced the bolts that I found on the bottom of the pan and used Locktite to keep them in place.
Problem solved.
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 26
Insgesamt: 1,928
