Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz) oder 2,5 GHz (Turbo Boost bis zu 3,7 GHz) Quad Core Intel Core i7 Prozessor mit 6MB geteiltem L3 Cache.
467 Fragen Alle anzeigen
Powers on, then powers off as if power button is held down
The other day, I opened my MacBook Pro and was surprised that it was shut off completely and not just asleep, but no biggie until I start it up and about 2-3 seconds later it shuts itself off. Tried it several times with the same result. I zapped the PRAM, tried booting restore volume as well as another startup disk, and none of that worked. Once or twice, it would boot up fast enough to see my desktop and click a couple of things to see that everything looked okay once in.
Then I reset the SMC. At first, it bricked. The power light on the charger went off and it wouldn't start at all no matter what I did. So I took the cover off the back and disconnected the battery which made it light up again, but still powered off after 2-3 seconds of coming on.
From my troubleshooting, I'm pretty sure there is something wrong with the power button. It acts as if it is stuck. Maybe something got into it? I popped the button off and blew some air in there but no sign of moisture or damage from the top.
Is there any way to test the power button? Does anyone have another theory or troubleshooting ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
6 Kommentare
Can you give us the exact model you have. If you can still see the serial number on your bottom cover you can find your system here: EveryMac - Lookup. Once you know paste the systems URL link here for us to see.
von
We need that exact machine as there are known issues on different models!
von
Sorry for the delayed response. The model is A1398.
I went to the Apple Store. They said there were several issues in the diagnostic that all go back to a bad logic board. The power stayed on when booted in diagnostics, BTW. As far as Apple is concerned, the only option is to pay $600 to get anything fixed it might need. While it seems like there should be a workaround at least, I'm starting to believe that is going to be the only option.
von
Which one?? A1398. Really need to know here.
We might have a better answer but without knowing which of the many models Apple has produced we just can't help you.
von
Is EMC 2881 the extra number you're looking for?
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Remove the bottom cover, disconnect the battery and disconnect the keyboard. Plug the charger in, if it turns itself off, there is likely a fault with the logic board. If not, it will be a fault with the keyboard.
I have seen your issue mainly in Macbook Airs a few times, where it will recognise a single press of the power button, but will act like you are holding down the power button once it is switched on.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
It's definitely the keyboard. If nothing else, maybe I can use an external for now.
von
To verify if the power switch its self is bad you can also turn the system on using the power pads shown here:
Short out the two contacts and if this works reliably then you'll need to replace the Upper Case or if you have the patience you could dive deeper by replacing the keyboard it self. Here is the IFIXIT guide you'll need to follow to get to the point of either replacing the upper case or going the next step replacing the keyboard: MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement. Once you get to the last step you can then remove the keyboard.
Here's a YouTube vid of someone doing a 2012 model with is basically the same: Macbook Pro 15" Retina A1398 Change Keyboard. This model uses plastic rivets which are a pain to get out which is why you see the force needed to pull out the old keyboard.
Here's your choices:
MacBook Pro 15" Retina (Late 2013-Mid 2014) Upper Case Assembly Bild
Produkt
$149.99
Bewertung 1
Antwort hinzufügen
Johnny Krenek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 562
