Zum Hauptinhalt wechseln
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
93 Fragen Alle anzeigen
tail lights no work
Hi! I have a problem on my 2004 Jeep Grand Cherokee.
the tail and license plate lights do not work, but the brake , directional back-up, and the hazard lights are working normally
Can You please help me to fix. my problem
and I also want to know where is the fuse of the tail lights
THANKS!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
are your front lights working or are they dark as well . There on the same fuse. If your front makeres are working then theres probably a break in the wire to the rear
von
I have power to my driver side rear lights all of them but I dont have anything on the passenger side all of a sudden. None of them work. All the bulbs are good. Any help would be greatly appreciated and all was working fine and then boom
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The fuse panel is located by the drivers left knee under the dash.
https://w05.dealerconnect.chrysler.com/s...
Hope this helps
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
your owners manual should have a breakdown of which fuse is which. if not use a multi meter to find the blown fuse
von
@chuyin ,Jesus Contreras , If after checking all fuses and bulb's and does not rectify the issue, check the bulb sockets them selves for corrosion, burnt, contacts may need pried up a bit(little) to enable grounding or power to the bulb, (this is a common issue) if contacts broke or badly burnt, replace the socket. Below are a couple links that may help. Good luck.
https://www.youtube.com/watch?v=BACokV7G...
http://repairpal.com/electrical-contacts...
Bewertung 2
1 Kommentar:
I was able to fix my son's 2004 Cherokee by switching sockets -- the tail/brake socket fits in the back-up socket and also the turn signal socket.
von
Antwort hinzufügen
Jesus Contreras wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 37
Letzte 30 Tage: 137
Insgesamt: 23,042
