Zum Hauptinhalt wechseln
Nintendo GameCube Controller DOL-003. Erschien im November 2001, kompatibel mit dem Nintendo GameCube, der Nintendo Wii und der Nintendo Wii U. Reparaturen an diesem Gerät sind nicht kompliziert und erfordern nur gewöhnliche Werkzeuge.
46 Fragen Alle anzeigen
"A" button working like a turbo controller?
I bought a gamecube controller from china, and everything seems to work fine. But in some games that I have to press and hold the "A" button the videogame understands that I press and release and press again the button many times.
Has anyone seen anything like this? And there's someway to fix it?
Thanks!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
There could be a series of problems with this issue you're reporting. Since it's a knock off controller it could be:
  • Damage to the PCB during manufacturing.
  • A bad button indicator.
  • Some kind of liquid making a crossed connection.
Get a tri-wing driver, open up the device and inspect it. Clean up the area with rubbing alcohol, inspect the button and the pad it rests on and look over the cuircit board to see if there are broken traces or other signs of damage. If you're having any issues determining the problem. Take a few pictures and add them to this post to see if there is anything you may have overlooked.
Hopefully, we can get this controller working properly again. Good luck!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Yuri Lelis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 430
