Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Front camera blurry and light leak from top corner after screen repair
I just repaired an iPhone 6 and used an iFixit front panel full assembly, screen worked fine however in the dark I noticed heavy light leak from the edges and also the front camera was blurry. Any suggestions as to a cause of this problem? And what is the recommended solution?
Thanks
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare:
Blurry front camera. Clean front camera lens and glass cover.
von
is the frame bent regarding the light leak?
von
No, the frame is not bent at all.
von
I get the same light leakage from beside the volume buttons nearly every time, I've tried checking for bends in the frame, I even used new frames and OEM parts but it still happens. Am I doing something wrong?
von
Einen Kommentar hinzufügen
1 Antwort
iPhone 6 has a very soft frame and I myself have fixed hundreds of them and see maybe... 1 of 20-25 with a straight housing. It wouldn't be the assembly so check again for that micro bend at the top, from a side view. Or even place the device, screen side down on a flat surface and tap a corner one by one to see.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Stelios Sgoutas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,167
