Zum Hauptinhalt wechseln
The aluminum PowerBook G4 was released by Apple to replace the previous titanium-body model. The 12" and 17" versions debutted in January 2003 with the 15" version following in September of that year.
683 Fragen Alle anzeigen
"mac-boot", "shut-down"? what to do
when i open my mac, it keeps saying "mac-boot" or "shut-down". i type mac-boot, it does its thing, shuts down. i open it again, it says the same thing, "mac-boot". this happened only after i opened my battery to check the airport card cause my mac said the airport card wasn't installed
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
It looks like it's booting in to openfirmware by default. Try resetting the PRAM. When you turn it on, hold "Command+Option+P+R" (All 4 Keys At Once) right after it makes the startup noise, and keep holding them until you hear it again.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
thanks it worked :)
von
it did not work for me
Bewertung 0
1 Kommentar:
You might try asking your own question as your problem and solution may be different.
von
Antwort hinzufügen
elise wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 936
