Zum Hauptinhalt wechseln
Xperia ZR is the waterproof phone from Sony that lets you film in Full HD underwater. Released in June 2013.
Any way to turn on phone without power button?
I ripped the cable connecting the power button and volume buttons. What other way can I check that the phone turns on ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Try: connecting the two Power cables that were attached to the button, if not, then try giving each of the power cables a bit of a shock == (Be careful not to short your phone, DO NOT LEAVE THE CURRENT ON FOR MORE THAN about 1 SECOND) ==
Edit 02/02/17
This was an idea because the power button may be jammed and this just sounded like a reasonable answer because when you connect the wires the system gets the signal to start up so try do this see what happens but try it on an old phone
War diese Antwort hilfreich?
Bewertung 0
@kurt_1411 help me lol
Bewertung 0
3 Kommentare:
LOL uh look at a teardown xD
von
The wires that used to be attached to the power button, try connecting them as if you were pressing the power button
von
I need a picture of your whole phone pls
von
Antwort hinzufügen
[deleted] wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 1,690
