Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für Apple LED Cinema Display 27". Hier findest du alles, was du für deine Apple LED Cinema Display 27" Reparatur brauchst.
What's this smudges on my LCD?
Hey guys,
What's this smudges on my screen? When my cinema display is cold, they don't appear, but when it gets hot (very hot), they get more and more stronger.
http://lucasveiga.com/media/IMG_1992-PV6...
I've seen some topics which the people say this can be some clouding, but I'm afraid this isn't that.
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
do they look like there on the display (e.g, are they pixelated?) or on the glass, because i have a very similar display, and i can't explain how smudgy it is.
von
I already removed the glass and the smudges are on LCD. :/
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There is a few causes of this:
  • Even though LCD's don't have the same issue of burn-in as older CRT's you still can get it! If you have a desktop image which is static with large dark & light sections you can get this effect.
  • If someone was servicing your system and pressed on the back of the LCD they could disrupt the liquid causing a dark splotch or line if the object was sharp.
  • Some displays glass plates did not get properly washed during the manufacturing process. This was a big problem for Apple with the 2011 21.5 & 27" iMac screens, some where also off color.
In this case I suspect it was your background image that burn't in.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
In one of these causes, what's the proper fix?
von
In all the cases I listed it requires a replacement screen ;-{
von
Antwort hinzufügen
Lucas Veiga wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 692
